1997 E4OD to ZF5 swap questions (NOW COMPLETE)
Well I got to say great fourm, I have done alot of reading on this topic, and I have found alot of answers this is basically to clear up a few questions I have.
First off I have a 1997 4x4 ext cab with a powerstroke and a E40D and I want to convert to manual.
I also just bought a 1992 4x4 ext cab with a 7.3 IDI and a 5 speed that I want to use as a donar truck.
What can I not use for this swap from the 1992?
Like Pedals, Drive lines, crossmember, flywheel, clutch, transfercase, transmission harness, shifter, floor piece....
Any help would be great Ii plan on starting the swap tomorrow or wednesday.
Ii also posted this question in another fourm so if that is a no no please let me know.
Also would any one be interested in any parts from the idi, or any of my automatic stuff?
Check the engine side of the harness against the engine side of the E4OD harness. If the large pigtail from your auto harness and the manual harness have the same layout then it will work regardless of where the wires are. You may have to jump them around some though to get the lights and a startup. After my swap the reverse lights came on but not the 4x4 lights and it wouldn't start with the key. A little moving around of the wires fixed that all right up.
I want to say that the pedalbox is a bit too early to fit right but am not certain.
As for the flywheel and clutch, I can't answer that. Someone will come along a know though. Good luck. It's a fun swap.
And welcome to FTE!
I guess I didnt really need to ask about the flywheel and clutch I plan on doing a single mass flywheel and a better the oem clutch anyways, I tow alot so I want something that is going to hold up. I also plan on doing some perfromance upgrades as time and money perments.
Is there anythings I should adress while the trans is out besides like maybe the downpipe and such?
how can i find out about the pedals? Should i use my E40D transfercase, or does it matter?
Either way, our clutch pedal position switch is a springloaded mech that you will connect onto the clutch master cylinder rod inside the cab. When the clutch is pushed in it activates that switch and closes the circuit needed to start the truck. Your truck is already wired for that. There is a pigtail up under your dash plugged into a grey piece with no wires coming out. That piece has the wires in the pigtail permanantly jumped so when your truck is in neutral or park it will crank. Once you buy the appropriate CPP switch and put it on the master cylinder rod you just take that jumper off the harness and plug the harness up to the switch. When you push the clutch from now on it will complete that circuit allowing the truck to start. It also disengages your cruise control when the clutch is pushed while the CC is activated.
I left my jumper in for now because it sure is convenient to just reach in and crank the truck. However, I have no neutral safety and my cruise will not deactivate from the clutch, only the brakes or button. My heim joint mod should be in any day and I'll probably hook the CPP switch back up for safety. When the plastic bushing wears out it is hit or miss if the master cylinder rod will travel far enough to close the circuit.
Clear as mud? Good. Ask again if that's hard to follow. I'm a bit distracted.
No sir. I thought the same and had some 91 pedals. Were nowhere close to fitting. Of course it could have been some weird one of a kind occurence and I could be wrong. I think the cutoff is 92 or 93 but don't know which. It's easy to tell though. Just take the pedalbox and kinda hold it up under your dash to compare. You should be able to tell pretty easy.
The 97 should have the 4407 ( I think that is the right no.), and the 92 should have the 1356 transfer case. The main difference is the way the driveshaft hooks to the case. The 1356 will have a slip joint, and the 4407 will be bolted solid to a flange. I would use the 4407.
Can I swap the yoke on the 1992 driveline?
I still need to get a PCM? preferably from a same year truck?
What are good options for clutches?
Well I am going to have to do this swap sooner thenm later, I lost my E4OD last night, it puked all of its fluids out in the middle of the road.
So my biggest questions right now are what are good options for clutch.
What is the difference between the two transfercases? can I swap the yokes on the drive shaft so i dont have to have a drive shaft made?
besides the down pipe anything else i should try and change?
and for sure the pedals from the 1992 wont work? what about pedals from like a 1995 f-150?
what master and slave cylinder do i use?
