Flow Chart - Back Yard Fixn on the 6.0 - Ford Truck Enthusiasts Forums
Old 10-10-2010, 06:27 PM
miner999r's Avatar
miner999r miner999r is offline
miner999r is gaining momentum as a positive member of FTE.miner999r is gaining momentum as a positive member of FTE.
Talking Flow Chart - Back Yard Fixn on the 6.0
After reading a lot of the posts on the site and noting some of the pickles folks get into, it reminded me to re-activate this old flow chart: It seems a fair complex motor that is too expensive and fine a work to mess up.
problem solving flowchart
Probably some of you experienced hands can re-write this one for 6.0 diesels and folks that should really not wrench on it?
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old 10-10-2010, 06:41 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
I like that!
Old 10-10-2010, 06:55 PM
06silvercrew's Avatar
06silvercrew 06silvercrew is offline
06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.06silvercrew has a very good reputation on FTE.
LMAO love it! Ima print that out and post it in the shop tomorrow.
Old 10-10-2010, 07:17 PM
texans's Avatar
texans texans is offline
texans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to behold
nice find miner999r
Old 10-10-2010, 07:46 PM
motor-man's Avatar
motor-man motor-man is offline
motor-man is starting off with a positive reputation.
This should definatly be read before each and every repair!!
Good one
No Start - When Hot OldWoodsDiesel 1994.5 - 1997 7.3L Power Stroke Diesel 14 03-11-2013 07:19 AM
Crank No Start Flowchart DIYMechanic 1994.5 - 1997 7.3L Power Stroke Diesel 15 07-19-2012 08:52 AM
Riff Raff Hoodies patrickke 1999 - 2003 7.3L Power Stroke Diesel 3 11-25-2010 01:10 AM
FE 390 Piston Selection logan.hawes FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 06-10-2010 06:19 PM
code 332 maxtruck00 1987 - 1996 F150 & Larger F-Series Trucks 18 06-08-2010 09:38 PM
Tags
60, 60l, 69l, chart, coolant, cooling, diagram, egr, engine, f150, ficm, flo, flow, flowchart, ford, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
