STEERING COLUMN WIRING
By -
These are generic steering column wiring codes for General Motors and Ford columns and should give you some direction doing your wiring. I'm fairly confident that both auto makers have made changes, additions and deletions to these tables, so a VOM or trouble light test BEFORE you throw the switch would be prudent. But, it will at lease give you a place to start looking for continuity.
G.M. STEERING COLUMN WIRING
COLOR
APPLICATION
White
Stop Light Switch
Green
R.R. Lamp
Yellow
L.R. Lamp
Purple
Turn Signal Flasher
Brown
Flasher
Dark Blue
L.F. Lamp
Light Blue
R.F. Lamp
Black
Horn
Orange
Ignition Switch
Dark Green
Ground
Tan
Ground
Red
Battery 12 V
Brown
Acc. Fuse Box
Pink
Ignition Coil
Red
Battery Fuse Box
Purple / Dbl White Stripe
Start On Solenoid
FORD STEERING COLUMN WIRING
COLOR
APPLICATION
White/Blue
R.F. Turn Signal
White/Red
Emergency Flasher
Green/White
L.F. Turn Signal
Green/Orange
L.R. Turn Signal
Green
Brake Light Switch
Orange/Blue
R.R. Turn Signal/Brake Lite
Blue
Turn Signal Flasher
Black/Green
Accessory
Black
To Fuse Box
Brown/Purple
Solenoid
White Or Red/Green
To Coil
Gray
Hot With Switch On
Yellow
Battery 12 Volt
Disclaimer: Requires some assembly, battery not included, do not operate heavy machinery while reading this information, not to be taken internally, your mileage may vary.
Comments ()
