Royal Purple’s Synthetic Lubricants Increase Protection, Fuel Economy and Longevity
By -
Porter, TX (September 4, 2006)”” Dreading the hills ahead of you? Worried about overheating or something breaking from the stress of your load? Tired of spending a fortune each trip to get there and back? Upgrading lubricants in your tow vehicle can save you time, money, and headaches.
Get More Power
Increased horsepower will make getting up that next hill much easier. Independent tests from Oklahoma State University, Horsepower TV and others document horsepower increases between 1.7% to 2.9% simply by switching to Royal Purple high performance motor oil.
Save Fuel
Independent tests from North Carolina State University, Hot Rod TV and others document fuel savings of up to 5% or more by switching to Royal Purple high performance motor oil. This can translate into a substantial savings especially as fuel prices climb higher year after year.
Keep It Cool
Royal Purple’s Purple Ice® has been shown in independent tests to reduce engine temperature as much as 30 degrees F. The reduction in temperature is achieved by reducing the surface tension of the coolant, which improves heat transfer throughout the cooling system. Purple Ice® lubricates water pump seals and is compatible with traditional ethylene glycol antifreeze (green) and GM Dex-Cool antifreeze.
Protect your rear
Royal Purple® Max-Gear® high performance gear oil reduces differential’s temperatures, dramatically reduces wear, saves energy and requires no OEM or aftermarket limited-slip additive. Royal Purple® Max-Gear® outperforms other GL-5 gear oils because it combines high-quality synthetic base oils with Royal Purple’s proprietary Synslide® additive technology. It provides maximum protection to heavily loaded gears while maximizing power output throughout the drivetrain. Max-Gear® also exceeds Eaton’s stringent GL-5 /MIL-L-2105D gear oil specifications.
Improve shifting
Synchromax® offers improved shift quality over a wide temperature range and reduced gear noise. It is fully compatible with all types of friction materials and offers excellent corrosion and oxidation protection without affecting the soft metals commonly found in manual transmission synchronizers. Royal Purple®  Synchromax® is recommended for all manual transmissions that specify an automatic transmission fluid or motor oil.
About Royal Purple
Royal Purple® makes synthetic products for all your automotive needs, including engine oils, transmission fluids, gear oil, coolant additives, power steering fluid, chain lubricant, grease, penetrating lubricant, and assembly lube. For more information on Royal Purple or its products, contact Royal Purple Ltd., One Royal Purple Lane, Porter, TX 77365, 281-354-8600,
www.royalpurple.com
Comments ()
