Pro comp 6-inch Suspension Systems for 2009 Ford F-150 2/4WD
The best just got better! The mighty F-150 is all new for 2009 and loaded with the latest features
and technology. Once again, Pro Comp is proud to be the first manufacturer to
have 6-inch performance suspension systems available for both 2 and 4 wheel
drive versions of these new trucks.
The engineering
team at Pro Comp used state-of-the-art CAD technology to develop new suspension
systems for the 2009 F-150. These sophisticated new systems deliver maximum
performance and control without compromising the AdvanceTrac® with Roll
Stability Control® (RSC®) systems now standard on all F-150s.
Key components in
the new 6-inch systems are super strong extended steering knuckles and stylish
new one-piece cross members that install easily and maintain proper CV axle
angles. Systems for 4WD also feature a integrated front differential skid plate
for added protection. New for 2009, cast rear block with integrated bumpstop
pads and height adjustable rear kit allows for added personalization of vehicle
stance.
Stage II systems
include MX2.75C Motorsport Series coil over front shocks and MX6 monotube 6
position adjustable rear shocks for optimum on and off road performance and
handling. Stage I systems feature front strut spacers and ES9000 rear shocks.
Allows use of up
to 37” x 12.50” tires on 20” or larger diameter wheels. Wheels can be up to
9.5” wide, with a max of 5.50” backspacing.
Source:
Pro Comp Suspension
