New Edge Evolution Programmers For Ford Powerstroke
By -
Edge Evolution
OGDEN, UT — One of Edge Products’ first diesel tuners was called the Evolution, a hand-held programmer that would reprogram your diesel’s ECU through the OBDII port in less than five minutes. It featured three power levels and amazing power increases. As Edge evolved, so did its programmers.
Now Edge has improved its Evolution stand-alone programmer and has integrated it into an Attitude-style display for a compact, powerful programmer with advanced monitoring features. The Evolution has three distinct power levels that deliver up to 100hp and 200 ft. lbs. of torque, and even has a power setting designed to consistently improve fuel economy. Additionally, these new Evolutions are the first-ever programmers to monitor EGTs (along with boost pressure and other safety features), negating the need for standard A-pillar gauges.
The Evolution comes standard with a custom pod that looks factory installed and is packed with features like: full engine data display with a backlight color-adjustable screen; checks and clears trouble codes; records 0-60 and ΒΌ-mile performance tests; displays alerts and records max RPM and vital fluid temps; adjusts for tire size and raises the speed limiter; plus it datalogs vital engine information and can be updated through the Internet.
The new Edge Evolution programmers are available for ’03-’07 Ford Powerstroke 6.0L, the ’06-’07 GM Duramax LLY/LBZ 6.6L, and will soon be available for other truck applications. For more information, please contact Edge Products, 1080 S. Depot Dr., Ogden, UT 84404, 888-360-3343, 801-476-3343, fax 801-476-3348.
Comments ()
