Lund Roll Pan Installation for 1973-1979 Ford F-series truck
By -
    By: John F. Daly III, aka "The TorqueKing".
    I purchased this product from www.etruckaccessories.com, an
    internet company out of Milwaukee, WI.
    I chose the Lund product over those offered by other companies like LMC
    Truck and JC Whitney because of the name brand, and I’ve heard many positive
    stories of the overall fit and finish of the Lund products.
    Project Total Price
    $141.50,
    delivered to my front door in 1 week, 5 working days
    (Note: this is pending the paint, estimated to be
    no more than $60)
    Parts List
         Lund P/N 20003, all necessary equipment included.
    Tools List
    Drill
    1/8" and/or 5/32" drill bit
    Ratchet (3/8" drive works best)
    5/16" and 7/8" socket
    13/16" combo or closed wrench
    Sharpie marker or alternate marking device (scratch awl, etc.)
    Skills required
    Minor drilling
    Basic fender alignment
    A helper is recommended, but not necessary
    There are five basic steps involved, as described and
    illustrated below.
    Step 1) Remove
    old bumper.
    There are two bolts on
    each framerail that will be holding your stock bumper. You’ll need a ratchet to loosen the nut, and
    a combo/closed end to hold the bolt on the other side. I found the nut to be a 7/8", and the bolt
    is 13/16".
    This one has seen better days, and many, many rear end
    collisions by soccer moms not paying attention in their minivans. Beware, your classic will be vulnerable to
    attack with the new fiberglass smoothie installed!
    It’s
    tempting to just send the roll pan back, it looks just too sweet without a
    bumper at all, sporting the chrome pipes and the ol 9", sending a visual
    warning to those import kids that you’ve got command of 300+ ft*lbs of torque! (that is, the ones who actually know what
    that means)
    Fit roll pan in position. Make sure the
    fiberglass piece fits correctly. You
    may need to adjust a few out of place fender pieces in the undercarriage.  Once you’ve found the correct position,
    flush with the tailgate, support it with duct tape. I prefer the "Black" tape, aka "300 MPH" tape, as drag racers
    refer to it, it’s got super-thick vinyl backing and a killer adhesive. Now open and close the tailgate to ensure
    that it’s motion is not hindered by the new piece, and make sure they do not
    make contact in any position.
    You may need a helper here while you tape it in
    position. Make sure you have it canted
    correctly, flush with all body lines.
    My "300 MPH" tape didn’t leave any residue on my finish, and held it
    perfectly in place.
    Step 3) Mark the
    position of the holes to be drilled.
    There are two holes on each end that need to be drilled for. The instructions say to use a 1/8" drill
    bit, but I found that drilling this small of a hole, only 1 of the 4
    self-tapping screws would actually engage their threads. I think a 5/32" bit would work better.
    My initial markings were �" too low on the
    first try, so I had to drill it twice.
    I used a Sharpie marker to mark the drill location, which barely fit
    through the holes in the fiberglass. To
    reach the metal through the holes on one side, I used a skinnier pencil dipped
    in shoe edge dressing (Heel and Sole, for those military guys who are all too
    familiar with this product), which made a distinct mark on the metal on the
    other side. Make sure that once you’re
    done, the roll pan is still in the correct position, mine had slipped down
    about a �" during the marking process, which I didn’t realize until had
    finished bolting it up.
    Here you can see the holes for the self-tapping
    screws. This was the difficult side to
    mark, as my Sharpie marker couldn’t reach through the smaller hole to mark the
    metal. I used a pencil dipped in Heel
    and Sole edge dressing.
    Step 4) Drill. My Makita cordless didn’t sweat biting
    through the skimpy undercarriage skin of my truck.
    Careful not to punch through to the rear lower skin that sits
    just 4" behind where you’ll have to drill.
    Make sure you do step #3 (marking) correctly the first time so you won’t
    have to do this step twice like I did.
    If you own a Dewalt drill, you might need to reserve an
    extra hour for this step, as your battery will surely be dead after a few
    seconds of this intense metal pounding (Chuck). Seriously, this is very easy drilling.
    Step 5) Install
    Roll Pan and bolt in.
    This would be
    very easy if not for the inconvenient space limitations you have to work
    with. If you can get the self-tapping
    screws to engage, then just throw on a ratchet (5/16" socket), and bolt it down
    until it’s snug, and securing the position of your new roll pan.
    If the screws won’t engage and tap, then
    repeat Step 4, except use a 5/32" drill bit.
    There is a center support bracket that you’ll need to drill for
    on the last crossmember of the frame, behind the gas tank, and then bend the
    strip that bolts to the center of the license plate area, underneath the plate
    itself, as necessary.
    The product comes in a white primer color, which isn’t too
    mismatched from my Oxford White finish.
    I’ll have it sprayed later this week, I’ll post pictures once I get it
    done. I really like the way it
    showcases the exhaust pipes, but they’re not clean in this photo, it was a
    rainy weekend in Georgia!
    In Conclusion, I’d
    like to say that this was a somewhat time-consuming process, it took me
    approximately two hours total, including all mishaps and lunch breaks.
    The overall visual effect of the roll pan is
    awesome, I can’t express how much better it looks over the old generic pickup
    bumper that used to live there. This is
    moderately stressful, as is any project that involves marking, drilling, and
    bolting in tight locations. The
    alignment is critical, so don’t rush through this, and have a helper nearby to
    ensure that you’ve got it aligned correctly.
    At $140 delivered to your front door, the custom look is hard to beat,
    and it’s a sure head-turner at the local cruise-in to see an old Ford Truck
    sporting sleek-looking body panels! I’d
    recommend keeping the old bumper in storage, in case your truck is called to
    towing duty. This also eliminates the
    license tag light, which may be illegal in your state, check all applicable
    laws before installing, but I don’t think too many policemen will have a
    problem, and if they’re glaring at you suspiciously, it’s probably in awe (or
    so we hope…). You’ll have to drive
    extra carefully with one of these installed, they offer no protection at all
    against teenage female drivers, or the morning makeup appliers!
    Overall, it’s a good weekend bolt-on that
    dramatically increases the overall look of your classic Ford.
    I was impressed by the quality of the Lund
    product, and the price was fair.
    -TK
Comments ()
Copyright 2017 Internet Brands, Inc. All rights reserved.
