Limit Your Slip: A Limited Slip Differential Primer
By -
116_0705_04_z+ford_8.8_rear_end+traction_lok_limited_slip
While off-road guys need absolute locked out traction; high performance drivers on a paved road need a differential that will still provide a forward lock and a limited amount of lock while turning for maximum drive off of the corner.
So how do we achieve that hard lock out of a corner without having the difficult time of trying to drive with both wheels spinning the same speeds all the time? By using a device called a limited slip differential also known as LSD. Specifically, we’ll be talking about the clutch-type LSD in this article.
128605-500-0
So, what makes this so different from a locker? Well, noise is the biggest difference you’ll notice right away. Lockers make so much noise due to the teeth ramping and slamming back into each other in order to lock back up.
Clutch-type LSDs, on the other hand, utilize clutch packs to limit the slip between the tires. On certain types of Clutch-type LSDs, you won’t see the center pin attached to the differential case.
Instead, the center pin rides inside the ramp assemblies where the spider gears are located. In Auburn and Trac-Lok differentials, the center pin still does attach to the differential case. There is a spring inside the LSD, however it only acts as a preload.
LSD Way new
Another difference is how the lock-up action occurs. Instead of being either locked or unlocked, but not in between, a clutch-type LSD can put pressure on the clutches to increase the break-away torque required and allow slip when that happens.
The clutch-type LSD can also provide a lock-up during deceleration. This is done by the ramp assembly and how it interacts with the center pin. That design can make a LSD act as a 1-way, 1.5-way, or 2-way.
A 1-way LSD will only lock on acceleration and will be open on deceleration because the center pin will be flat along with the deceleration side of the carrier. A 1.5-way LSD will have a wider ramp on the deceleration side to provide some lock-up during deceleration. Then a 2-way will provide lock-up on acceleration and deceleration with equal force as both ramps are the same shape.
Find more answers to your questions in the forum.>>
Check out these videos on the clutch-type LSD:
How LSDs work
1-way, 2-way, 1.5-way Explained
Understanding Limited Slip Differential (Trac-Lok Style)
Justin Banner is a regular contributor to LS1Tech and JK Forum, among other auto sites.
How to Guides
View All >
10 People Who Made the Ford Motor Company What It Is Today
Slideshow: Ten people who shaped the modern Ford Motor Company.
Read It
Roush Gives the 2024 Ford F-150 Visual and Performance Overhaul
Slideshow: Roush never disappoints when it comes to their takes on Ford vehicles.
Read It
Ford F-150 Lightning Purchase Turns Into a Nightmare for Owner
Slideshow: Luckily, the automaker was willing to help.
Read It
Top 10 WORST Excuses to NOT Buy a Ford Truck!
Slideshow: Ten worst excuses for not buying a Ford truck or SUV.
Read It
