Installing a Do It Yourself Bed Liner (Part 3)
By -
Copyright © 2001 Kenneth Payne, All International Rights
By Ken Payne
Then open the can and stir the contents completely. Here was the first snag in the project. The lid edges are very poorly designed and made of very soft metal. The liner material on the inside of the can tends to glue the lid closed. With the soft lid material, I almost ended up destroying the lid opening the can! It was a major hassle trying to open it!
Pour some of the liner material into a paint roller pan. The use the supplied brush to apply the material to the edges, corners and under the bed rail lip.
Using the supplied roller, start applying the liner to the remainder of the bed. I highly recommend you buy an adjustable paint roller pole. You may be able to get the first coat done without it, but not the second coat unless you want to crawl all over the first coat!
Click here for page 4 of this article.
Comments ()
