How to replace the backlight bulb in a 1992 Ford DIN style radio
How to replace the backlight bulb in a 1992 Ford DIN style radio.
By Patrick Fogle
Items needed:
  • #1 Phillips Screwdriver
  • Needle nose pliers
  • 1 #37 bulb
Step 1:
Turn all controls to one side or the other, make them all the same for easier reassembly (as seen above).
Step 2:
Pull the knobs off, this may require some effort.
Step 3:
Remove screws that hold the face on. Highlighted in red
Step 4:
Gently remove the face. This can be tricky, so be careful not to break any wires. Again the bulb is highlighted in red.
Step 5: Use the pliers to replace the bulb. Be gentle it is glass. I have found it is possible to do it without breaking the bulb.
Comments ()
