How to change the Camshaft Position Sensor on a 7.3 Power Stroke Diesel
Article By: John Heimel
style="MARGIN: 0in 0in 0pt"> face="arial,helvetica,sans-serif">1. Make sure you have the correct part. style="mso-spacerun: yes"> This depends on the serial
number of your engine which should be located on a sticker below the
front of the plastic cover for the fuel bowl. style="mso-spacerun: yes"> Neither Ford or International
calls it a "CPS", Ford calls it a CMP sensor and
International calls it a CAMP sensor.
face="arial,helvetica,sans-serif" size="2">
class="MsoNormal" style="MARGIN: 0in 0in 0pt"> style="FONT-SIZE: 14pt; mso-bidi-font-size: 13.0pt"> face="arial,helvetica,sans-serif"
size="2">
class="MsoNormal" style="MARGIN: 0in 0in 0pt"> style="FONT-SIZE: 14pt; mso-bidi-font-size: 13.0pt"> face="arial,helvetica,sans-serif" size="2">Ford Part #’s: style="mso-spacerun: yes"> Before engine serial #375549 style="mso-tab-count: 1">
F6T012K073A
class="MsoNormal" style="MARGIN: 0in 0in 0pt"> style="FONT-SIZE: 14pt; mso-bidi-font-size: 13.0pt"> size="2"> style="mso-tab-count: 4">
Serial #375549 and above
F7T012K073A
size="2">
class="MsoNormal" style="MARGIN: 0in 0in 0pt"> style="FONT-SIZE: 14pt; mso-bidi-font-size: 13.0pt"> face="arial,helvetica,sans-serif" size="2">International Part
#’s: Before engine serial
#375549
1821720C98
1825899C93
size="2">
class="MsoNormal" style="MARGIN: 0in 0in 0pt"> style="FONT-SIZE: 14pt; mso-bidi-font-size: 13.0pt"> face="arial,helvetica,sans-serif" size="2">2. style="mso-spacerun: yes"> Remove the #9 fuse under the
hood (not in the dash).
size="2">
class="MsoNormal" style="MARGIN: 0in 0in 0pt"> style="FONT-SIZE: 14pt; mso-bidi-font-size: 13.0pt"> face="arial,helvetica,sans-serif" size="2">3. style="mso-spacerun: yes"> You may want to remove the belt
for easier access, but it’s not necessary.
size="2">
class="MsoNormal" style="MARGIN: 0in 0in 0pt"> style="FONT-SIZE: 14pt; mso-bidi-font-size: 13.0pt"> face="arial,helvetica,sans-serif" size="2">4. style="mso-spacerun: yes"> Disconnect the CMP sensor
electrical connector. The
sensor is located towards the bottom left on the front of the
engine. You’ll see the
single wire bundle going to the sensor.
size="2">
class="MsoNormal" style="MARGIN: 0in 0in 0pt"> style="FONT-SIZE: 14pt; mso-bidi-font-size: 13.0pt"> face="arial,helvetica,sans-serif" size="2">5. style="mso-spacerun: yes"> Remove the old CMP sensor using
a 10mm socket. Be careful
not to round off the bolt (there is only 1). style="mso-spacerun: yes"> It’s on there real tight and is
tough to get to.
size="2">
class="MsoNormal" style="MARGIN: 0in 0in 0pt"> style="FONT-SIZE: 14pt; mso-bidi-font-size: 13.0pt"> face="arial,helvetica,sans-serif" size="2">6. style="mso-spacerun: yes"> Take the new CMP sensor and coat
the seal with either motor oil or Vaseline and intall it. style="mso-spacerun: yes"> Install the bolt and reconnect
the wire connector.
size="2">
class="MsoNormal" style="MARGIN: 0in 0in 0pt"> style="FONT-SIZE: 14pt; mso-bidi-font-size: 13.0pt"> face="arial,helvetica,sans-serif" size="2">7. style="mso-spacerun: yes"> Reinstall the #9 fuse under the
hood and you should be ready to go.
Comments ()
