Holiday Gift Idea #4: Air Lift Air Springs
By -
Air Lift adjustable air springs (also called air bags) let you properly distribute weight to all four tires when towing or hauling a heavy load. The air springs work with your existing leaf or coil suspension to give you more load support in the front or rear of your vehicle when you need it. Simply inflate the air springs when you need more load support and deflate when you don’t.
Available at Airliftcompany.com
Holiday Gift Idea #5: Analyze This >>>>>
Comments ()
