F-Series and E-Series Diagnostic Trouble Codes And Repair Procedures
By -
Special thanks to Pat Barrett and the folks at Level Ten Products for this article. Many of the parts needed to repair the issues can be purchased from Level Ten Products and we recommend you visit their web site or give them a call at (973) 827-1000.
The E40D and 4R100 codes are for gas and diesel for 1996 – 2003 E and F-series Super Duty (250 350 450 550). In 2004 they changed to a 5R110 transmission and the codes are different. The codes for 4R70W and 4R75w are for F-150 and E-150 1996- 2006.
Diagnostic
Trouble Code Chart E4OD- 4R100
Five
Digit DTC
Component
Description
Condition
Symptom
Action
P0102
P0103
P1100
P1101
MAF
MAF concerns MAF system
has a malfunction which may cause a transmission concern.
High or low
EPC pressure, incorrect shift schedule. Incorrect torque
converter clutch engagement scheduling. Symptoms similar to a
throttle position (TP) failure.
WIRING OR MAP
SENSOR
P0117
ECT
ECT indicates
125°C (257°F)
Voltage drop
across ECT exceeds scale set for temperature 125°C (257°F)
(grounded).
Torque
converter clutch will always be off, resulting in reduced fuel
economy.
WIRING OR ECT
SENSOR
P0118
ECT
ECT indicates
-40°C (-40°F)
Voltage drop
across ECT exceeds scale set for temperature -40°C (-40°F)
(open circuit).
Torque
economy.
WIRING OR ECT
SENSOR
P0122
P0123
P1120
TP
TP concern PCM has
detected an error that may cause a transmission concern.
Harsh
engagements, firm shift feel, abnormal shift schedule, torque
converter clutch does not engage, torque converter clutch
cycling.
WIRING OR TP
SENSOR
P1702
Digital
TR
Intermittent
DTC codes P0705 or P0708
Refer to DTC
codes P0705 or P0708 condition.
Refer to DTC
codes P0705 or P0708 symptom.
WIRING OR
DIGITAL TR SENSOR
P1704
Digital
TR
Digital TR
circuit reading in between gear position during KOEO/KOER
Digital TR
sensor or shift cable incorrectly adjusted; or digital TR
circuit failure.
Wrong
commanded EPC pressure. Digital TR reading the wrong gear
position.
WIRING OR
DIGITAL TR SENSOR
P0705
Digital
TR
Digital TR
circuit failure
Digital TR
circuits, indicating an invalid pattern in TR_D. Condition
caused by a short to ground or an open in TR4, TR3A, TR2 and
or TR1 circuits. This DTC cannot be set by an incorrectly
adjusted digital TR sensor.
Increase in
EPC pressure (harsh shifts). Defaults to (D) or D for all gear
positions. In (D) position trans, stuck in D or manual 2.
WIRING OR
DIGITAL TR SENSOR
P0708
Digital
TR
Digital TR
sensor circuit TR3A open
Digital TR
sensor circuit TR3A reading 2.6v – 5.0v (open circuit). This
DTC cannot be set by an incorrectly adjusted digital TR
sensor.
Increase in
EPC pressure. Defaults to (D) or D for all gear ranges.
WIRING OR
DIGITAL TR SENSOR
P1705
Digital
TR
Digital TR
self test was not carried out in PARK or NEUTRAL
Vehicle not
in PARK or NEUTRAL during on-board diagnostic.
Rerun
on-board diagnostic in PARK or NEUTRAL.
WIRING OR
DIGITAL TR SENSOR
P0715
TSS
Insufficient
input from turbine shaft speed sensor
PCM detected
a loss of TSS signal during operation.
Harsh shifts,
harsh torque converter clutch activation and harsh
engagements.
WIRING OR TSS
SENSOR
P0717
TSS
Turbine shaft
speed sensor signal intermittent
PCM has
detected an intermittent TSS signal.
Harsh shifts,
engagements.
WIRING OR TSS
SENSOR
P0718
TSS
Turbine shaft
speed sensor signal noisy
PCM has
detected a noisy TSS signal.
Harsh shifts,
engagements.
WIRING OR TSS
SENSOR
P0720
OSS
Insufficient
input from output shaft speed sensor
PCM detected
a loss of OSS signal during operation.
Harsh shifts,
abnormal shift schedule, no torque converter clutch
activation.
WIRING OR OSS
SENSOR
P0721
OSS
OSS sensor
signal noisy
PCM has
detected an erratic OSS signal.
Harsh shifts,
engagement.
WIRING OR OSS
SENSOR
P0722
OSS
wiring
Insufficient
input from OSS
PCM has
detected a loss of OSS signal.
Harsh shifts,
engagement.
WIRING OR OSS
SENSOR
P0731
SSA,
SSB or internal parts
1st gear
error
No 1st gear. Incorrect
gear selection, depending on failure or mode and manual lever
position. Shift errors may also be due to other internal
transmission concerns (stuck valves, damaged friction
material). Engine rpm could be higher or lower than expected.
PTS
HYDROSYSTEM IF THERE IS LOTS OF DEBRIS IN PAN YOU WILL NEED
PTS KIT AND PTS BILLET TORQUE CONVERTER
P0732
SSA,
2nd gear
error
No 2nd gear. Incorrect
PTS
P0733
SSA,
3rd gear
error
No 3rd gear. Incorrect
PTS
P0734
SSA,
4th gear
error
No 4th gear. Incorrect
PTS
P0741**
TCC,
internal components
TCC slippage
detected
The PCM
picked up an excessive amount of slippage during normal
vehicle operation.
TCC
slippage/erratic or no torque converter clutch operation.
Flashing Transmission Control Indicator Lamp (TCIL).
PTS BILLET
TORQUE CONVERTOR AND PTS HYDROSYSTEM.
IF THERE IS
LOTS OF DEBRIS IN PAN YOU WILL NEED PTS KIT
P0743*
TCC,
wiring, PCM
TCC solenoid
circuit failure during on-board diagnostic
TCC solenoid
circuit fails to provide voltage drop across solenoid. Circuit
open or shorted or PCM driver failure during on-board
diagnostic.
Short
circuit: engine stalls in second (OD, 2 range) at low idle
speeds with brake applied.
Open circuit: torque converter clutch never engages. May flash
TCIL.
WIRING OR PTS
HYDROSYSTEM
P0750*
SSA,
wiring, PCM
SSA solenoid
circuit failure
SSA circuit
failed to provide voltage drop across solenoid. Circuit open
or shorted or PCM driver failure during on-board diagnostic.
Incorrect
gear selection depending on condition mode and manual lever
position. See Solenoid On/Off Chart.
WIRING OR PTS
HYDROSYSTEM
P0753
SSA,
wiring, PCM
SSA
electrical failure
SSA circuit
fails to provide voltage drop across solenoid. Circuit open or
Incorrect
gear depending on condition mode and manual lever position.
See Solenoid On/Off Chart. May flash TCIL.
WIRING OR PTS
HYDROSYSTEM
P0755*
SSB,
wiring, PCM
SSB solenoid
circuit failure
SSB circuit
Incorrect
WIRING OR PTS
HYDROSYSTEM
P0758*
SSB,
wiring, PCM
SSB
electrical circuit failure
SSB circuit
Incorrect
WIRING OR PTS
HYDROSYSTEM
P1714
SSA,
internal components
SSA
malfunction
Mechanical
failure of the solenoid detected.
Incorrect
gear selection depending on condition, mode and manual lever
position. See Solenoid Operation Chart.
PTS
HYDROSYSTEM
P1715
SSB
SSB
malfunction
Mechanical
Incorrect
PTS
HYDROSYSTEM
P0781**
SSA
or internal parts
1-2 shift
error
Engine rpm
drop not detected when 1-2 shift was commanded by PCM.
Incorrect
gear selection depending on failure or mode and manual lever
material).
PTS
HYDROSYSTEM
IF THERE IS
LOTS OF DEBRIS IN PAN YOU WILL NEED PTS KIT AND BILLET TORQUE
CONVERTER
P0782**
SSA,
2-3 shift
error
Engine rpm
drop not detected when 2-3 shift was commanded by PCM.
Incorrect
material).
PTS
HYDROSYSTEM.
IF THERE IS
CONVERTER
P0783**
SSA,
3-4 shift
error
Engine rpm
drop not detected when 3-4 shift was commanded by PCM.
Incorrect
material).
PTS
HYDROSYSTEM.
IF THERE IS
CONVERTER
P1703
BPP
BPP switch
circuit failed
Brake ON/OFF
circuit failure.
Failed on or
not connected “” torque converter clutch will not engage at
less than 1/3 throttle. Failed off or not connected “” torque
converter clutch will not disengage when brake is applied.
WIRING OR BPP
SWITCH
P1703
BPP
Brake not
actuated during on-board diagnostic
Brake not
cycled during KOER.
Failed off or
WIRING OR BPP
SWITCH
P0713
TFT,
wiring, PCM
-40°C (-40°F)
indicated TFT sensor circuit open
Voltage drop
across TFT sensor exceeds scale set for temperature -40°C
(-40°F).
Firm shift
feel.
WIRING OR TFT
SENSOR
P1711
TFT
TFT out of
on-board diagnostic range
Transmission
not at operating temperature during on-board diagnostic.
Warm vehicle
to normal operating temperature.
P0712
TFT,
wiring, PCM
157°C (315°F)
indicated TFT sensor circuit grounded
Voltage drop
across TFT sensor exceeds scale set for temperature of 157°C
(315°F).
Firm shift
feel.
WIRING OR TFT
SENSOR
P1713
TFT
wiring PCM
TFT
continually reading cold
TFT sensor in
range low failure.
Firm shift
feel. Substitute ECT for TFT
WIRING OR TFT
SENSOR
P1783
TFT
Transmission
over temperature condition indicated
Transmission
fluid temperature exceeded °C (270°F).
Increase in
EPC pressure.
WIRING OR TFT
SENSOR CLOGGED COOLER
P1718
TFT,
wiring, PCM
TFT
continually reading hot
TFT sensor in
range high failure.
Firm shift
feel. Substitute ECT for TFT.
WIRING OR TFT
SENSOR
P0740
TCC,
wiring, PCM
TCC
electrical failure
TCC circuit
fails to provide voltage drop across solenoid. Circuit open,
shorted or PCM driver failure during on-board diagnostics.
Short
circuit, engine stalls in 2nd ((D), 2 range) at low speeds
with brake applied. Open circuit, torque converter clutch
never engages. May flash TCIL.
P1740
TCC
TCC
malfunction
Mechanical
Failed on “”
Engine stalls in 2nd (O/D, Manual 2 ranges) at low idle speeds
with brake applied. Failed off “” Torque converter never
applies.
PTS
HYDROSYSTEM.
IF THERE IS
CONVERTER
P1741**
TCC,
internal components
Excessive
torque converter clutch engagement error
Excessive
variations in slip (engine speed surge) across the torque
converter clutch.
Engine rpm
oscillation is present in 3rd gear.
PTS
HYDROSYSTEM,BILLET TORQUE CONVERTOR.
IF THERE IS
P1742
TCC,
internal components
TCC solenoid
failed on
TCC solenoid
has failed on by electric, mechanical or hydraulic concern.
Harsh shifts. PTS
IF THERE IS
P1743
TCC,
internal components
TCC solenoid
failed on
TCC solenoid
Harsh shifts. PTS
IF THERE IS
P1744
TCC
TCC The PCM
picked up an excessive amount of TCC slippage during normal
vehicle operation.
TCC
PTS
IF THERE IS
P1746*
P0960
EPC,
wiring, PCM
EPC solenoid
open circuit
Voltage
through EPC solenoid is checked. An error will be noted if
tolerance is exceeded.
Open circuit
causes maximum EPC pressure, harsh engagements and shifts.
WIRING OR
SUPER SOLENOID
P1747*
P0962
EPC,
wiring, PCM
EPC solenoid
circuit failure, shorted circuit or output driver
Voltage
Short circuit
causes minimum EPC pressure (minimum capacity) and limits
engine torque (alternate firm).
WIRING OR
SUPER SOLENOID
P1760
EPC,
wiring, PCM
EPC solenoid
PCM detected
a loss of EPC during operation.
Unexpected
reduction in engine torque.
WIRING OR
SUPER SOLENOID.
P17811
4×4
Low switch
4×4 Low
switch closed
4×4 Low
switch closed or 4×4 Low indicator lamp circuit open.
Failed on “”
early shift schedules in 4×2 and 4×4 HI range. Failed off “”
shifts delayed in 4×4 Low.1
WIRING OR 4X4
SWITCH
P0748**
EPC
solenoid
EPC solenoid
circuit failure
Voltage
Short circuit
results in minimum EPC pressure (minimum capacity) and limits
engine torque (alternate firm). Not all gears present. Open
circuit: maximum PC A pressure, harsh engagements and shifts.
WIRING OR
SUPER SOLENOID.
P1729
4×4
Low
4×4 Low
switch failure
4×4 Low
switch failure during normal vehicle operation.
Early shifts,
harsh shifts, increase in electronic pressure control valve.
WIRING OR 4X4
SWITCH
P1728
Trans
Transmission
slip error
The PCM has
detected an excessive amount of slippage during normal
operation.
Transmission
slippage erratic or no torque converter clutch operation.
COMPLETE
TRANSMISSION FAILIER
Chart 4R70-75W
Five Digit DTC
Component
Description
Condition
Symptom
Action
P0102
P0103
P1100
P1101
MAF
MAF concerns MAF system has a malfunction which may
High or low EPC pressure, incorrect shift
schedule. Incorrect torque converter clutch engagement scheduling.
Symptoms similar to a throttle position (TP) failure.
WIRING OR MAP SENSOR
P0117
ECT
ECT indicates 125°C (257°F) Voltage drop across ECT exceeds scale set
for temperature 125°C (257°F) (grounded).
Torque converter clutch will always be
off, resulting in reduced fuel economy.
WIRING OR ECT SENSOR
P0118
ECT
ECT indicates -40°C (-40°F) Voltage drop across ECT exceeds scale set
for temperature -40°C (-40°F) (open circuit).
P0122
P0123
P1120
TP
TP concern PCM has detected an error that may cause
Harsh engagements, firm shift feel,
abnormal shift schedule, torque converter clutch does not engage, torque
converter clutch cycling.
WIRING OR TP SENSOR
P1702
Digital TR
Intermittent DTC codes P0705 or P0708 Refer to DTC codes P0705 or P0708
condition.
symptom.
WIRING OR DIGITAL TR SENSOR
P1704
Digital TR
Digital TR circuit reading in between
Digital TR sensor or shift cable
incorrectly adjusted; or digital TR circuit failure.
Wrong commanded EPC pressure. Digital TR
reading the wrong gear position.
P0705
Digital TR
Digital TR circuit failure Digital TR circuits, indicating an
invalid pattern in TR_D. Condition caused by a short to ground or an open
in TR4, TR3A, TR2 and or TR1 circuits. This DTC cannot be set by an
incorrectly adjusted digital TR sensor.
Increase in EPC pressure (harsh shifts).
Defaults to (D) or D for all gear positions. In (D) position trans, stuck
in D or manual 2.
P0708
Digital TR
Digital TR sensor circuit TR3A open Digital TR sensor circuit TR3A reading
2.6v – 5.0v (open circuit). This DTC cannot be set by an incorrectly
Increase in EPC pressure. Defaults to (D)
P1705
Digital TR
Digital TR self test was not carried out
in PARK or NEUTRAL
Vehicle not in PARK or NEUTRAL during
Rerun on-board diagnostic in PARK or
NEUTRAL.
P0715
TSS
Insufficient input from turbine shaft
speed sensor
PCM detected a loss of TSS signal during
operation.
Harsh shifts, harsh torque converter
clutch activation and harsh engagements.
WIRING OR TSS SENSOR
P0717
TSS
Turbine shaft speed sensor signal
intermittent
PCM has detected an intermittent TSS
signal.
P0718
TSS
Turbine shaft speed sensor signal noisy PCM has detected a noisy TSS signal. Harsh shifts, harsh torque converter
P0720
OSS
Insufficient input from output shaft
speed sensor
PCM detected a loss of OSS signal during
operation.
Harsh shifts, abnormal shift schedule, no
torque converter clutch activation.
WIRING OR OSS SENSOR
P0721
OSS
OSS sensor signal noisy PCM has detected an erratic OSS signal. Harsh shifts, abnormal shift schedule, no
torque converter clutch engagement.
P0722
OSS wiring
Insufficient input from OSS PCM has detected a loss of OSS signal. Harsh shifts, abnormal shift schedule, no
P0731
SSA, SSB or internal parts
1st gear error No 1st gear. Incorrect gear selection, depending on
failure or mode and manual lever position. Shift errors may also be due to
other internal transmission concerns (stuck valves, damaged friction
PTS HYDROSYSTEM IF THERE IS LOTS OF
DEBRIS IN PAN YOU WILL NEED PTS KIT AND PTS BILLET TORQUE CONVERTER
P0732
2nd gear error No 2nd gear. Incorrect gear selection, depending on
P0733
3rd gear error No 3rd gear. Incorrect gear selection, depending on
P0734
4th gear error No 4th gear. Incorrect gear selection, depending on
P0741**
TCC, internal components
TCC slippage detected The PCM picked up an excessive amount of
slippage during normal vehicle operation.
TCC slippage/erratic or no torque
converter clutch operation. Flashing Transmission Control Indicator Lamp (TCIL).
PTS BILLET TORQUE CONVERTER AND PTS
HYDROSYSTEM.
WILL NEED PTS KIT
P0743*
TCC, wiring, PCM
TCC solenoid circuit failure during
on-board diagnostic
TCC solenoid circuit fails to provide
voltage drop across solenoid. Circuit open or shorted or PCM driver
Short circuit: engine stalls in second
(OD, 2 range) at low idle speeds with brake applied.
Open circuit: torque converter clutch never engages. May flash TCIL.
WIRING OR PTS HYDROSYSTEM
P0750*
SSA, wiring, PCM
SSA solenoid circuit failure SSA circuit failed to provide voltage
drop across solenoid. Circuit open or shorted or PCM driver failure during
Incorrect gear selection depending on
condition mode and manual lever position. See Solenoid On/Off Chart.
P0753
SSA, wiring, PCM
SSA electrical failure SSA circuit fails to provide voltage drop
Incorrect gear depending on condition
mode and manual lever position. See Solenoid On/Off Chart. May flash TCIL.
P0755*
SSB, wiring, PCM
SSB solenoid circuit failure SSB circuit fails to provide voltage drop
P0758*
SSB, wiring, PCM
SSB electrical circuit failure SSB circuit fails to provide voltage drop
P1714
SSA, internal components
SSA malfunction Mechanical failure of the solenoid
detected.
condition, mode and manual lever position. See Solenoid Operation Chart.
PTS HYDROSYSTEM
P1715
SSB
SSB malfunction Mechanical failure of the solenoid
detected.
PTS HYDROSYSTEM
P0781**
SSA or internal parts
1-2 shift error Engine rpm drop not detected when 1-2
material).
PTS HYDROSYSTEM.
WILL NEED PTS KIT AND BILLET TORQUE CONVERTER
P0782**
2-3 shift error<;/td>
Engine rpm drop not detected when 2-3
material).
PTS HYDROSYSTEM.
P0783**
3-4 shift error Engine rpm drop not detected when 3-4
material).
PTS HYDROSYSTEM.
P1703
BPP
BPP switch circuit failed Brake ON/OFF circuit failure. Failed on or not connected “” torque
converter clutch will not engage at less than 1/3 throttle. Failed off or
not connected “” torque converter clutch will not disengage when brake is
applied.
WIRING OR BPP SWITCH
P1703
BPP
Brake not actuated during on-board
diagnostic
Brake not cycled during KOER. Failed off or not connected “” torque
applied.
P0713
TFT, wiring, PCM
-40°C (-40°F) indicated TFT sensor
circuit open
Voltage drop across TFT sensor exceeds
scale set for temperature -40°C (-40°F).
Firm shift feel. WIRING OR TFT SENSOR
P1711
TFT
TFT out of on-board diagnostic range Transmission not at operating temperature
Warm vehicle to normal operating
temperature.
P0712
TFT, wiring, PCM
157°C (315°F) indicated TFT sensor
circuit grounded
scale set for temperature of 157°C (315°F).
P1713
TFT wiring PCM
TFT continually reading cold TFT sensor in range low failure. Firm shift feel. Substitute ECT for TFT WIRING OR TFT SENSOR
P1783
TFT
Transmission over temperature condition
indicated
Transmission fluid temperature exceeded
°C (270°F).
Increase in EPC pressure. WIRING OR TFT SENSOR CLOGGED COOLER
P1718
TFT, wiring, PCM
TFT continually reading hot TFT sensor in range high failure. Firm shift feel. Substitute ECT for TFT. WIRING OR TFT SENSOR
P0740
TCC, wiring, PCM
TCC electrical failure TCC circuit fails to provide voltage drop
across solenoid. Circuit open, shorted or PCM driver failure during
Short circuit, engine stalls in 2nd ((D),
2 range) at low speeds with brake applied. Open circuit, torque converter
P1740
TCC
TCC malfunction Mechanical failure of the solenoid
detected.
Failed on “” Engine stalls in 2nd (O/D,
Manual 2 ranges) at low idle speeds with brake applied. Failed off “”
Torque converter never applies.
PTS HYDROSYSTEM.
P1741**
Excessive torque converter clutch
engagement error
Excessive variations in slip (engine
speed surge) across the torque converter clutch.
Engine rpm oscillation is present in 3rd
gear.
PTS HYDROSYSTEM,BILLET TORQUE CONVERTER.
WILL NEED PTS KIT
P1742
TCC solenoid failed on TCC solenoid has failed on by electric,
Harsh shifts. PTS HYDROSYSTEM,BILLET TORQUE CONVERTER.
WILL NEED PTS KIT
P1743
WILL NEED PTS KIT
P1744
TCC
TCC The PCM picked up an excessive amount of
TCC slippage during normal vehicle operation.
WILL NEED PTS KIT
P1746*
P0960
EPC, wiring, PCM
EPC solenoid open circuit Voltage through EPC solenoid is checked.
An error will be noted if tolerance is exceeded.
Open circuit causes maximum EPC pressure,
WIRING OR SUPER SOLENOID
P1747*
P0962
EPC, wiring, PCM
EPC solenoid circuit failure, shorted
Short circuit causes minimum EPC pressure
(minimum capacity) and limits engine torque (alternate firm).
P1760
EPC, wiring, PCM
PCM detected a loss of EPC during
operation.
Unexpected reduction in engine torque. WIRING OR SUPER SOLENOID
P17811
4×4 Low switch
4×4 Low switch closed 4×4 Low switch closed or 4×4 Low
Failed on “” early shift schedules in
4×2 and 4×4 HI range. Failed off “” shifts delayed in 4×4 Low.1
WIRING OR 4X4 SWITCH
P0748**
EPC solenoid
EPC solenoid circuit failure Voltage through EPC solenoid is checked.
Short circuit results in minimum EPC
pressure (minimum capacity) and limits engine torque (alternate firm). Not
all gears present. Open circuit: maximum PC A pressure, harsh engagements
and shifts.
P1729
4×4 Low
4×4 Low switch failure 4×4 Low switch failure during normal
vehicle operation.
Early shifts, harsh shifts, increase in
P1728
Trans
Transmission slip error The PCM has detected an excessive amount
of slippage during normal operation.
Transmission slippage erratic or no
COMPLETE TRANSMISSION FAILURE
Comments ()
