A 2015 Ford F-150 Build
Once you’ve completed one build, it’s impossible to not want to dip your hands into another. As some might say, working on, modifying, and building up rides can be an addiction. A sometimes costly and time consuming addiction, at that. Of course, the reality is that there are much worse things to be addicted to, so we, and we’re sure many others, won’t apologize for the guilty pleasure of taking on a project.
FTE member Go-on3 has one project already under his belt, where he built a 2012 Ford F-150 into a dream machine. So since that one was finally completed, he picked up a 2015 Ford F-150 last month, and hopes that it will turn out just as good as his previous build. So far, he has added a DJM Suspension 3″ drop in the front, 6″ inch drop in the rear, 22″ Verde Invictas wheels with 305-40-22 Goodyear Fortera SL tires, and more. Many additional parts are currently in the fabrication shop and on the way, so expect this build to move steadily!
Go check out Go-on3’s build thread and show your support!
