August 31, 1999 – 2000 Ford Explorer
By -
Source: Ford Motor Company
2000 Ford
Explorer
2001 Ford Explorer Sport Trac
specifications
Powertrain
Engine type
4.0L SOHC V-6
Fuel type, grade
Unleaded gasoline
Power – SAE net (projected)
206 @ 5,000 rpm
Torque – SAE net (projected)
238 @ 4,000 rpm
Transmission
Type: Ford 5R55E 5-Speed Automatic Overdrive,
electronically controlled
Steering and Suspension
Turning Circle
4×2
4×4
Curb-to-Curb (ft.)
43.1
43.1
Wall-to-Wall (ft.)
44.9
44.9
Track Width/Tread Width
Front (in.)
58.5
58.5
Rear (in.)
58.5
58.5
Tires and Wheels
4×2
4×4
4×4
(with Premium Sport Group option)
Tires
P235/75-15, All Season, Outlined White Letter
P235/75R-15, All Terrain, Outlined White
Letter
P255/70R-16, All Terrain, Outlined White
Letter
Size (in.)
15
15
16
Wheels
Type
Silver styled steel
Silver styled steel
Bright cast aluminum
Size (in.)
15
15
16
Brakes
Type
Front disc/ rear drum w/four-wheel antilock braking
system
Dimensions
4×2
4×4
Exterior (in.)
Overall length
205.9
205.9
Overall width
71.8
71.8
Overall height at curb
70.0
70.0
Wheelbase
125.9
125.9
Front overhang
34.6
34.6
Rear overhang
45.4
45.4
Approach angle, curb
26.8°
26.6°
Departure angle, curb
22.4°
22.5°
Front tread
58.5
58.5
Rear tread
58.5
58.5
Interior (in.)
Front
Headroom
39.4
39.4
Shoulder room
56.7
56.7
Maximum leg room
42.4
42.4
Hip room
52.7 52.7
Rear
Headroom
38.9
38.9
Shoulder room
56.9
56.9
Maximum leg room
37.8
37.8
Hip room 52.7 52.7
Cargo (in.)
Cargo area length at floor
50.6
50.6
Cargo area height
19.7
19.7
Cargo area volume (cu.ft.)
33.0
33.0
Cargo width at wheelhouse
41.2
41.2
Tailgate to ground (curb)
31.6
31.6
Fuel tank (gallons)
Usable capacity
20.5
20.5
Payload (lb.)
4×2
4×4
Maximum payload capacity
1,520
1,480
Base Curb Weight
4×2
4×4
Base curb weight (lb.)
4,117
4,332
Base GVWR (lb.)
5,380
5,560
Trailer Towing
4×2
4×4
Max. trailer tow (lb.)
5,300
5,100
Comments ()
