August 25, 1999 – 2001 F-150 SuperCrew Specifications
By -
specifications
SIZE="+1" face="arial">Powertrain
Note: PRELIMINARY SPECIFICATIONS 8/23/99
Vehicle Type: Pickup Truck
Model Configuration: Crew Cab
Engine
Engine type 4.6-liter SOHC 2-valve Triton™ V-8 5.4-liter SOHC 2-valve Triton™ V-8
Displacement 281 cu. in. 330 cu. in.
Bore, in. 3.55 in. 3.55 in.
Stroke, in. 3.54 in. 4.16 in.
Compression ratio: 9.0:1 9.0:1
Fuel type, grade: Unleaded gasoline, 91(RON) octane Unleaded gasoline, 91(RON) octane
Power (SAE net horsepower) 220@4,500 rpm 260@4,500 rpm
Torque/rpm 290@3250 350@2500
Transmission Automatic Automatic
Type 4 Speed Electronically Controlled 4 Speed Electronically Controlled
Steering and
Suspension
Wheels XLT (std.) Lariat (std.), XLT (opt.)
  16 in. 17 in.
Brakes
4-wheel disc, 4-wheel ABS
Dimensions
Exterior Dimensions
Front Overhang 38.7
in.
Wheelbase 139.0 in.
Height 73.9 in. (4×2), 76.9 (4×4)
Width: 79.1 in.
Length: 225.9 in.
Pickup Box (cargo) vol. 44.2 cu.ft.
Cargo Width @ Wheelhouse 50.0 in.
Pickup Box Length: 67.2 in.
Pickup Box Height: 20.2 in.
Capacities
Interior Dimensions
Volume 113.8 cu.
ft.
Head Room 39.8 in. (front), 39.8 in.
(rear)
Shoulder Room 63.7 in. (front), 63.6 in.
(rear)
Leg Room 41.0 in. (front), 36.8 in.
(rear)
Hip Room 59.8 in. (front), 58.0 in.
(rear)
Rear Knee Clearance 2.5 in.
Fuel Capacity 25
gallons
Base curb weight
(lbs.)
4.6-liter engine 5.4-liter engine
4×2 4×4 4×2 4×4
  4,581 4,914 4,697 5,032
All dimensions in inches unless otherwise
specified.
Comments ()
