2009 F-150 TECHNICAL SPECIFICATIONS
By -
POWERTRAIN/CHASSIS* indicates E85 performance
POWERTRAIN
4.6L 2V V-8
4.6L 3V EFI V-8
5.4L 3V Triton V-8
Engine Type
V-8 iron block, aluminum heads
Bore/Stroke
3.55 x 3.54 in.
3.55 x 3.55 in.
3.55 x 4.16 in
Displacement
281 cu in, 4606 cc
281 cu in, 4606 cc
330 cu in, 5400 cc
Compression Ratio
9.4:1
9.8:1
9.8:1
Fuel Injection
Sequential multi-port electronic
Valvetrain
SOHC, 2 valves per cylinder
SOHC, 3 valves per cylinder
SOHC, 3 valves per cylinder, Variable Camshaft Timing
Power
248 hp @4,750 rpm
292 hp @ 5,700 rpm
320 hp @ 5,000 rpm* /310 hp@ 5,000 rpm
Torque
294 lb.-ft. @ 4,000 rpm
320 lb.-ft. @4,000 rpm
390 lb.-ft @ 3,500 rpm* /365 lb.-ft @3,500 rpm
Oil Capacity
6 qt
6 qt
7 qt
Coolant Capacity
19.7 qt
20.0 qt
20.7 qt
Transmission Type
4-speed automatic O/D (4R75E)
6-speed automatic overdrive (6R80E)
6-speed automatic overdrive (6R80)
Gear Ratios
6-speed automatic O/D
1st
2.48:1
4.17:1
4.17:1
2nd
1.56:1
2.34:1
2.34:1
3rd
1.00:1
1.52:1
1.52:1
4th
0.70
1.14:1
1.14:1
5th
0.86:1
0.86:1
6th
0.69:1
0.69:1
Reverse
2.32:1
3.40:1
3.40:1
Available Axle Ratios
3.15:1 / 3.31:1 / 3.55:1 / 3.73:1
SUSPENSION
 Front
4×2
Coil-on-shock, long-spindle double wishbone independent, stamped steel lower control arm
4×4
 Rear
4×2
Hotchkiss-type non-independent live, leaf springs and outboard shock absorbers
4×4
STEERING
Type
power rack-and-pinion
Overall Ratio
20.0:1
(126-in, 133-in, 145-in wheelbase and 157-in wheelbase with Max.
Trailer Tow) 17.0:1 (157-in wheelbase without trailer tow, 163-in
wheelbase)
Turning Circle,
Curb-To-Curb
see Dimensions and Capacities
BRAKES
Front
13.0-in vented disc
Rear
13.7-in vented disc
Assist Type
Vacuum, RSC
WHEELS AND TIRES
Base Wheel and Tires
17-in steel, P235/70R17 (4×2) and P235/75R17 (4×4)
Largest Wheel Available and Tires
20-in aluminum, P275/55R20 AS (4×2) and P275/55R20 AT (4×4)
FUEL ECONOMY (city/hwy)
4×2 4.6L 2V V-8 4-spd auto
14/19
4×2 4.6L 3V V-8 6-spd auto
15/20
4×2 5.4L V-8 6-spd auto
14/20
4×2 4.6L 3V V-8 SFE
Projected 15/21
4×4 4.6L 2V V8 4-spd auto
14/18
4×4 4.6L 3V V8 6-spd auto
14/19
4×4 5.4L V8 6-spd auto
14/18
DIMENSIONS AND CAPACITIES
Regular Cab
  SuperCab
  SuperCrew
6.5ft
8 ft.
5.5ft
6.5ft
8ft
5.5ft
6.5 ft.
4×2
4×4
4×2
4×4
4×2
4×4
4×2
4×4
4×2
4×4
4×2
4×4
4×2
4×4
EXTERIOR
Wheelbase
126.0
126.0
144.5
144.5
133.0
133.0
144.5
144.5
163.0
163.0
144.5
144.5
157.0
157.0
Overall Length
213.1
213.1
231.7
231.7
219.9
219.9
231.7
231.7
250.3
250.3
231.7
231.7
243.7
243.7
Overall Height
74.6
74.6
76.2
76.2
74.4
76.3
71.5
75.9
75.9
76.7
74.3
76.2
74.3
76.4
Overall Width (excluding mirrors)
78.9
78.9
78.9
78.9
78.9
78.9
78.9
78.9
78.9
78.9
78.9
78.9
78.9
78.9
Track Width, Front
67.0
67.0
67.0
67.0
67.0
67.0
67.0
67.0
67.0
67.0
67.0
67.0
67.0
67.0
Track Width, Rear
67.0
67.0
67.0
67.0
67.0
67.0
67.0
67.0
67.0
67.0
67.0
67.0
67.0
67.0
Cargo Box Length
78.8
78.8
97.4
97.4
67.0
67.0
78.8
78.8
97.4
97.4
67.0
67.0
78.8
78.8
Width (max) Between Wheels
50
50
50
50
50
50
50
50
50
50
50
50
50
50
Inside Box Height
22.4
22.4
22.4
22.4
22.4
22.4
22.4
22.4
22.4
22.4
22.4
22.4
22.4
22.4
INTERIOR
Seating Capacity
5/6
5/6
5/6
5/6
5/6
5/6
5/6
5/6
5/6
Headroom
   Front
41.0
41.0
41.0
41.0
41.0
41.0
41.0
41.0
41.0
41.0
41.0
41.0
41.0
41.0
   Rear
39.7
39.7
39.7
39.7
39.7
39.7
40.3
40.3
40.3
40.3
Legroom
   Front
41.4
41.4
41.4
41.4
41.4
41.4
41.4
41.4
41.4
41.4
41.4
41.4
41.4
41.4
   Rear
33.4
33.4
33.4
33.4
33.4
33.4
43.5
43.5
43.5
43.5
Hiproom
   Front
60.5
60.5
60.5
60.5
60.5
60.5
60.5
60.5
60.5
60.5
60.5
60.5
60.5
60.5
   Rear
66.6
66.6
66.6
66.6
66.6
66.6
64.6
64.6
64.6
64.6
Shoulderroom
   Front
66.6
66.6
66.6
66.6
66.6
66.6
66.6
66.6
66.6
66.6
65.9
65.9
65.9
65.9
   Rear
65.8
65.8
66.8
66.8
66.8
66.8
65.6
65.6
65.6
65.6
Fuel Capacity (gal)
Standard
26.0
26.0
26.0
26.0
26.0
26.0
26.0
36.0
26.0
36.0
26.0
36.0
26.0
36.0
Optional
36.0
36.0
36.0
36.0
36.0
36.0
36.0
36.0
36.0
36.0
Turning Circle, Curb-To-Curb (ft)
41.7
41.7
47.0
47.0
43.5
43.5
47.0
47.0
52.3
52.3
47.0
47.0
50.4
50.4
All Dimensions are in inches unless otherwise noted.
 WEIGHT AND TOWING (Pounds)
Regular Cab
SuperCab
SuperCrew
126"WB
145"WB
133"WB
145"WB
163” WB
145"WB
157"WB
4×2
4×4
4×2
4×4
4×2
4×4
4×2
4×4
4×2
4×4
4×2
4×4
4×2
4×4
WEIGHT (lbs.)
Base Curb Weight
4.6L 2V
4743
4971
4843
5092
4985
5317
5067
5384
5156
5289
4.6L 3V
5011
4903
5142
5042
5367
5127
5434
5186
5546
5319
5596
5.4L
5103
4985
5231
5162
5507
5210
5493
5314
5628
5391
5683
5.4L HD pkg
5135
5436
55161
58201
Payload Capacity
4.6L 2V
1650
1620
1850
1800
1460
1320
1580
1410
1590
1450
4.6L 3V
1680
1890
1850
1450
1370
1620
1460
1660
1340
1520
1340
5.4L
1610
2010
1910
1480
1380
1730
1650
1730
1510
1650
1460
5.4L HD pkg
3030
2700
GVWR
4.6L 2V
6450
6650
6750
6950
6500
6700
6700
6850
6800
6800
4.6L 3V
6750
6850
7050
6550
6800
6800
6950
6900
6950
6900
7000
5.4L
6800
7050
7200
6700
6950
7000
7200
7100
7200
7100
7200
5.4L HD pkg
8200
8200
82001
82001
CONVENTIONAL TOWING – Maximum Loaded Trailer Weight Ratings (lbs. )
Regular Cab
4×2
Regular Cab
4×4
SuperCab
4×2
SuperCab
4×4
SuperCrew
4×2
SuperCrew
4×4/AWD
ENGINE
AXLE
RATIO
MAX.
GCWR
(LBS.)
126.0"
WB
145”
WB
126.0"
WB
145"
WB
133"
WB
145"
WB
163” WB
132.5"
WB
144.5"
WB
163.0"
WB
145"
WB
157"
WB
145"
WB
157"
WB
4.6L EFI 2V V-8
Automatic
3.55
10600
5500
5300
5200
5100
3.73
11100
6000
5800
5800
5500
5700
5600
4.6L 3V  V-8
Automatic
3.15
3.31
13000
13500
8200
7500
8100
8000
3.55
14900
9500
9500
9300
3.73
15100
9400
9300
9200
5.4L 3-Valve
Triton V-8
Automatic
3.15
14000
8600
8500
8400
3.31
13200
7800
3.55
15300
9800
9700
3.73
17000
11300
5.4L 3-Valve Triton V-8 Automatic w/HD
3.73
17100
11000
Note: Maximum loaded trailer weights shown. The
combined weight of the towing vehicle (including hitch, passenger,
cargo) and the loaded trailer must not exceed the Gross Combination
Weight Rating (GCWR).
Note: See RV and Trailer Towing Guide for requirements, restrictions and 5th-wheel towing.
Comments ()
