2006 F-250 Super Chief Concept Specifications
TECHNICAL SPECIFICATIONS
POWERTRAIN AND CHASSIS | |
ENGINE | |
Type | Supercharged tri-fuel V-10 |
Configuration | V-10 |
Valvetrain | SOHC, two valves per cylinder |
Displacement | 6.8-liter |
Horsepower | Hydrogen: 280 @ 4,250 rpm; Gasoline: 310 @ 4,250 rpm; E85 310 @ 4,250 rpm |
Torque (ft-lb) | Hydrogen: 400 @ 3,250 rpm; Gasoline: 425 @ 3,250 rpm; E85: 425 @ 3,250 rpm |
Supercharter boost | Hydrogen: 18 psi; Gasoline: none; E85: none |
Fuel economy | Hydrogen: 13.6 miles per kg; Gasoline: 12 mpg; E85: 8.6 mpg |
Emissions | Hydrogen: SULEV; Gasoline: ULEV; E85: ULEV |
Range | Hydrogen: 150 miles; Gasoline: 336 miles; E85: 241 miles |
DRIVETRAIN | |
Layout | Four-wheel drive |
TRANSMISSION | |
Type | TorqShift™ five-speed automatic transmission |
SUSPENSION | |
Front | Twin coil monobeam, shock absorbers, stabilizer bar |
Rear | Live axle with leaf springs, staggered shock absorbers, stabilizer bar |
WHEELS | |
24-inch wheels | |
DIMENSIONS | |
EXTERIOR | |
Wheelbase | 175 in. (4445 mm) |
Overall length | 265 in. (6731 mm) |
Overall width | 92.2 in. (2343 mm) |
Overall height | 78.7 in. (1999 mm) |
Track width, front/rear | 80 in. (2032 mm) |
Front overhang | 38 in. (965 mm) |
Rear overhang | 51 in. (1295 mm) |
