2004 Ford Super Duty F350 Review
By -
The Ford 2004 Super Duty F350 adds the Harley Davidson edition to the line up, along with a few overall changes to the trims. All 2004 F350 SuperCab and Super Crew trims include the option for a power sliding rear window. The XLT and Lariat trims include a rear bench seat with convenience features like integrated cup holders and head restraints. Fog lamps are available for all XLT trims, and XL trims include reclining front bench seats.
Standard equipment with all 2004 F350 pickups is a radio, tachometer, ABS brakes, air bags for both passenger and driver, interval wipers, towing prep package, front air dam, locking pickup tailgate, cargo area tie downs, and pickup truck cargo box light. Standard for all except XL trims are power door locks, power windows, air conditioning, cruise control, tilt steering, tilt steering column, steering wheel mounted controls, front split bench seat, and power adjustable exterior mirror.
The 2004 F350 is available in dark toreador red, arizona beige, silver, basic black, chestnut, dark green satin, dark shadow gray metallic, estate green, wedgewood blue, oxford white, and true blue. Optional with all F350 models is a tow hitch receiver, sliding rear pickup truck window, mud guard, skid plate, electronic parking aid, daylight running lights, cassette player, cargo area cover, cargo net, load bearing exterior racks, and pickup truck bed liner.
A 5.4L 260hp 16-valve gas engine with 350 ft lbs of torque @ 2500 rpm is standard in all 2004 Ford Super Duty F350 pickups except for the dual-rear-wheel model (DRW). The standard engine included with all DRW trims is a 6.8L 310hp 20-valve gas engine with 425 ft lbs of torque @ 3250 rpm. The optional engine for all trims is a 6.0L 325hp 32-valve diesel engine with Electronic Fuel Injection and 560 ft lbs of torque @ 2000 rpm”‚ÄĚdesigned specifically to work with a 5-speed TorqShift automatic transmission.
A 6-speed manual overdrive transmission is standard with all trims. A 4-speed automatic and 5-speed TorqShift automatic transmissions are optional for all 2004 Ford Super Duty F350 models.
For a more in-depth look, go to our specs section.
Comments ()
