2004 F250 Sway Bar Bushing Replacement
By -
Ford
Super Duty Truck Sway Bar
Bushing Replacement
2004
F250 4×4 XLT Sport
For
my truck, diagnosing the sway bar bushings as the problem was very easy. I noticed the typical ‘clunking’ under the floorboards as I
drove over potholes and such. As I laid under the truck, my Dad shook it by pushing on
the top of the driver’s side window opening (with the window rolled down) and
I could EASILY see the sway bar rocking around inside the rubber bushings that
mount to the axle.
Tools
& Parts Needed
 Energy Suspension bushing kit part number 4.5186G
 15mm socket and/or wrench
 18mm socket and/or wrench
 13mm socket and/or wrench
 Shop press is helpful
Procedure
First
I disconnected the end links by removing the two bolts that go through the sway bar
and end link, one on each side. Note – I had to use the ‘after’ pictures to illustrate the first few
steps because I decided to write this article after I had the sway bar and end
links removed.
Next
I disconnected the sway bar from the axle by removing four nuts, two on each
side.
Next
I removed the driver’s side end link by removing the bolt that goes through the
end link, spacer block, and frame.
Next,
on the passenger’s side, I removed the bolt that goes through the end link and
frame.  You cannot remove the end link at this point because the bolt hits
on the exhaust pipe.  So, you must remove two bolts from the bottom side of
the frame, that connect up into the spacer block.
Now you can remove the passenger side end link.
Now,
I imagine that this part goes MUCH easier if you have a press.  I do have a press so I
didn’t attempt to do this without one but it seems like it would be rough.
Anyway, you must press out the old bushings from the end links.
Once
all four original bushing assemblies have been removed, you can install the
urethane bushings in the end links.  Apply a layer of grease (included in
the bushing kit) to the inside of the end link eye.  If you look at the end
links you’ll notice that the eye on one end is wider than the other. Use the bushings stamped 2592 on the ‘wide’ end and those stamped 2593 on the ‘narrow’ end. I used the press to install the bushings and to install the metal
spacers.  I also put a layer of grease on the inside of the bushings before
inserting the metal spacer.
Now
you can remove the old bushings from the sway bar and install the new ones in
the same location.  Also remember to apply the grease to the inside of
these bushings where they contact the sway bar.
Now
it is time to reinstall everything.  I first reinstalled the sway bar
to the axle.  Again, I put a layer of grease on the outside of the
bushings, where the U-shaped metal straps contact the bushing.  I
reinstalled the four nuts and left them loose.
Next,
I reinstalled the passenger side end link by inserting the bolt (with washer) into the end
link and through the block mentioned above.  There is a shoulder on this
bolt that is a very tight fit on the inside diameter of the metal sleeve. Again, I used the press to install this bolt into the sleeve.
Next
I installed the two bolts back through the bottom of the frame, into the block, and left them
loose.  Then, I tightened the bolt that goes through the end link, block, and
frame.  Then tightened the two bolts that go up into the block.
Next
I inserted the bolt (with washer) that goes through the lower end link eye and the sway bar,
and tightened it. This bolt also has a shoulder on it, but the fit is not as tight so I did
not need to press it in.  At this point I tightened the two nuts that
connect the sway bar to the axle, on the passenger side.
Next
I installed the driver’s side end link by first inserting the bolt (with washer)
through the
top end link eye (this bolt also has a tight fit like mentioned above), block, and
frame. Then I installed the bolt (with washer) that goes through the lower end link eye,
and the sway bar.  Then I tightened both bolts and the two nuts that
connect the sway bar to the axle, on the driver side.
Now
you’re done!  Enjoy your now non-clunking super duty suspension!
Comments ()
