11/05/2002 – Preliminary Technical Specifications – Triton V-8
By -
Source: Ford Motor Company
PRELIMINARY TECHNICAL SPECIFICATIONS – TRITON V-8
5.4-liter, 3-valve Triton™ V-8 Engine
Engine data
Engine type
Single-overhead-cam (SOHC) 3-valve, 90-degree V-8
Cylinder heads manufactured Windsor (Ontario) Engine Plant
Final engine assembly at Essex (Ontario) Engine Plant
Displacement
5.4 liters (330 cubic inches)
Bore
3.55 in. / 90.2 mm
Stroke
4.17 in. / 105.8 mm
Compression ratio
9.8:1
Power
300 hp SAE net @ 5,000 rpm
Torque
365 lb.-ft. SAE net @ 3,750 rpm
90 percent of torque available from 2,250 rpm to 4,750 rpm
Cylinders
90-degree V-8
Head
Aluminum alloy with magnesium cam covers
Block
deep-skirted cast iron with cross bolted main bearing caps
Intake manifold
Composite Intake Air Fuel Module, with charge-motion control valves and 75 mm electronically-controlled throttle body
Crankshaft
Internally balanced, Forged steel
Valve gear
Single overhead cam with variable cam timing, acting on stamped steel roller-finger followers
Included valve angle
11 degrees
Valve sizes
2 x 33.8 mm intake / 1 x 37.5 mm exhaust
Pistons
Lightweight, low crevice volume, hypereutectic cast aluminum with anti-friction skirt coating, and hard anodized top ring land
Connecting rods
Cracked powdered metal
Injection
Sequential multiport fuel injection
Ignition
Coil-on-plug
Oil capacity
6 quarts (5.7 liters )
Emissions Level
LEV2
Recommended fuel
87 octane Pump (R+M)/2
Comments ()
