03/20/2005 – 2005 Sport Trac Adrenalin Concept, World’s First High-Performance Sport Utility Truck – Specifications
By -
2005 Sport Trac Adrenalin  2005 Sport Trac Adrenalin
 Overview
 Specifications
 Photos
TECHNICAL SPECIFICATIONS
   BODY
Construction Steel body on fully boxed frame
   ENGINE
Type V-8
Manufacturing Location Romeo, Michigan
Configuration Cast-iron block and aluminum heads
Intake Manifold Cast-aluminum with Roots-type supercharger and air-to-water intercooler
Exhaust Manifold Cast iron
Crankshaft Forged Steel
Throttle body Dual 55-mm, electronic
Valvetrain DOHC, 4 valves per cylinder
Pistons Hypereutectic aluminum
Connecting Rods Forged H-beam steel
Bore x stroke 3.55 x 3.54 in (90.2 X 90.0 mm.)
Displacement 281 cu. in. / 4,606 cc
Compression ratio 9.85:1
Horsepower 390
Torque 390 lb-ft.
Fuel capacity 22.5 Gallons
   DRIVETRAIN
Layout All-wheel drive
Transmission 6-speed automatic overdrive
   SUSPENSION
Front Independent short- and long-arms (SLA) architecture with coil-over shocks, 32-mm stabilizer bar
Rear Independent Trailing Blade short- and long-arm (SLA) architecture with coil-over shocks, 25-mm stabilizer bar
   STEERING
Type Low-friction rack and pinion with power assist
Steering column Tilt
Ratio 18.9:1
   TIRES AND WHEELS (TYPE, SIZE)
Standard 295/45R21 custom Goodyear tires and 21 – x 9-in machined aluminum wheels
   EXTERIOR
Wheelbase 113.7 in.
Overall length 193.5 in.
Overall width 73.5 in.
Overall height 72.8 in.
Track width, front/rear 60.9/62.0 in.
   INTERIOR
Seating capacity 4 passenger
Headroom
  Front row 39.8
  Second row 38.7
Legroom
  Front row 42.4
  Second row 36.9
Shoulder room
  Front row 59.0
  Second row 59.0
Hip room
  Front row 55.4
  Second row 55.5
Estimated towing capacity 6,000 lbs. (estimated)
Comments ()
